  • 1.  'opaque' material not 100% opaque
    Posted 10-13-2015 16:52
    I have a material that SHOULD be 100% opaque. However when it is put on line there is a slight ghosting of the BG. I was given advice to put a second layer above the layer that holds the photoshop file in the material but that hasn't fixed it. Any suggestions? If I use xpression material the layer is opaque, but not with the photoshop files. I have tried to put a second quad with xpression black material behind the quad in question but as soon as I put the photoshop layer on, it goes slightly transparent. Any suggestions?
  • 2.  RE: 'opaque' material not 100% opaque
    Posted 10-13-2015 16:57
    Have you tried using PNGs instead of PSDs? I've noticed there is a slight glow around the edges of PSDs when brought into sequence. Wondering if PSDs and their color modes may have anything to do with it.
  • 3.  RE: 'opaque' material not 100% opaque
    Posted 10-13-2015 17:23
    I usually use .png files. I tried .psd with and without a separate alpha channel. I've tried jpg. I've tried laying multiple levels of the same material. I've tried a second quad with xpression black. It's a pretty simple gradient, so I think it would be easiest to just duplicate that gradient using xpression tools instead of photoshop. Thanks for the suggestion Hunter.
  • 4.  RE: 'opaque' material not 100% opaque
    Posted 10-15-2015 01:04
    Hi Malcolm,
    This is another case where it would be easier if we could see the scene/images you are referring to.. Could you post a link?
  • 5.  RE: 'opaque' material not 100% opaque
    Posted 10-16-2015 21:35
    Brian, not to over simplify but its basically one quad, with one png material (opacity 100%) on that quad. But unless you key it on our Ross switcher you can't see the issue. But I will set up a link. We have open scrimmage tonight otherwise I would get it posted today. Thanks
