Brian,
Thank you for the info.
It sound as if my next two questions are answered by you already....
Is there a way to "simulate" INPUT LIVE video on a Design Seat of Xpression?
I must say, I never thought to ask this. It's a good question from Cassie.
Is there a way to do it where you could use Any type of input we could set up hardware wise? A simple BM Decklink card, etc.?
Is there a way we could play a movie file from the Design machine hardware and it thinks of it as a Live Feed?
You say to add a virtual input to the hardware setup of XP designer. When doing this the input will either be black or color bars ONLY. Basically a test signal. When this then is replaced by the Studio box as the SDI input...
What then are the steps in this replacement process?
Thank you for the guidance and help.
Anthony
