  • 1.  golf stat datalinq search by player
    Posted 02-15-2019 01:44
    i have been asked to work on a golf build and pull live stats via rss feed
    http://www.golfstatresults.com/webse...urnFormat=JSON
    the client has asked to be able to pull players stats on a L-3rd by using their ID # on array 12. i do alot of data linking on many builds but i have never recieved a feed where the stats arnt labled for each player. here is what i tried to do in the column "DATA<array<12>=%NUM%>\array<6>" to pull name but im guessing the extra "<>" are throwing off the search. any one have ideas on how to write the column to make it pull name by number search?
  • 2.  RE: golf stat datalinq search by player
    Posted 02-15-2019 14:45
    This is not currently supported, the search fields must have names. It is something we could potentially add support to in the next release of XPression.
    What version are you currently running?
  • 3.  RE: golf stat datalinq search by player
    Posted 02-15-2019 14:53
    im currently building on a version of 7.2 not sure of the build off top of my head
  • 4.  RE: golf stat datalinq search by player
    Posted 02-15-2019 20:20
    This feature will be available in beta versions of 8.7 next week, so as long as you are up to date on software maintenance agreements we could arrange to get you the 8.7 beta to test it. This will be available officially tested in the version 9.0 release later in the year.
  • 5.  RE: golf stat datalinq search by player
    Posted 02-15-2019 20:25
    sadly i know that we are not up to date with our software maintenance. despite my best efforts to get my boss to pay for it. i got lucky and talked to the developer and he re wrote the json file to add in the named pairs so i was able to get the linqs to work
