  • 1.  Items showing up larger all of a sudden
    Posted 07-07-2015 19:16
    So I have a couple of graphics that recently have started showing up larger than when they were created. It kind of looks like if you were to crank Z-position up. But nothing seems different about these two random graphics in regards to any settings. One is a L3 another is a full screen. Has anyone else had this happen to them?
  • 2.  RE: Items showing up larger all of a sudden
    Posted 07-07-2015 19:43
    Is it consistently wrong with those two graphics even after restarting/reloading the project? If so, can you post a dropbox or google link to the project?
  • 3.  RE: Items showing up larger all of a sudden
    Posted 07-08-2015 19:46
    Yes it has been consistent with these two even after restarting and deploying and such. Do you want the .XPF file or the .XPP file?
  • 4.  RE: Items showing up larger all of a sudden
    Ideally the XPP.. If it is too large, then you could import those two scenes (and maybe one that isn't messed up), into a new project and send that as an XPP..
  • 5.  RE: Items showing up larger all of a sudden
    Posted 07-08-2015 20:05
    WSET project file
    I think I did the link correctly. I made a new project with the messed up ones. and some normal ones.
  • 6.  RE: Items showing up larger all of a sudden
    Posted 07-08-2015 20:11
    Thanks William.. I'm looking into the issue and will get back to.. You can remove the link now if you don't want it public..
  • 7.  RE: Items showing up larger all of a sudden
    Posted 07-08-2015 20:25
    William,
    I am still in the beginning stages of the investigation, but it looks like perhaps some of the graphics (the ones that are the correct size) were imported from a project that was built as 1920x1080 and imported into your project that was 1280x720; and then others were built native as 720p. Can you give us more info on the history of these scenes and if indeed they were imported between projects of different resolutions?
    I notice that if I create a new quad in the "broken" scene and set it to exactly 1280x720 then it fits the screen perfectly. If you do the same in the "Good" scenes, the 1280x720 quad is actually smaller than the scene.. Leading me to realize that the "good" scene is actually the one behaving strangely (and I believe must have been created originally with a 1920x1080 raster)
  • 8.  RE: Items showing up larger all of a sudden
    Posted 07-09-2015 22:07
    Brian,
    When the graphics were created, they were done by an outside company that did them in 1080. But We are 720 so we re-sized them in the program to work in the 720 world. And Many of the things that I created from scratch were based on 720. And Anything New that I made based on anything from 1280 were also resized to 720. And things have been basically fine for years.
    Hope that made sense
