  • 1.  Playing different scene directors
    Posted 10-11-2018 18:45
    I have 3 different scene directors, an animate in, play scene, animate out. Right now they all play at the same time when I take it online. I want to play/trigger them individually any suggestions.
  • 2.  RE: Playing different scene directors
    Posted 10-11-2018 21:12
    You have to make sure that you have "TRIGGERS" in each scene director that will activate a particular one when YOU want it to go. The trigger element should also have a connection to the Transition Logic of the main scene group.
    For example: You need to have a transition logic that will activate the Scene Director when you take it Online, but that same Transition Logic can be set to also take it Offline. Make sure you have the accurate name of your scene director in the transition logic rules AND in the Trigger element within the wanted Scene Director.
  • 3.  RE: Playing different scene directors
    Posted 10-12-2018 00:59
    You want to use transition logic for this. Set your in scene director as your and your out as the out. Then, in the scene directors, you'll want to make your play scene the default scene. What'll happen now is that when you take the scene online, the in scene director will play. During this time, the play scene director will play while the scene is online. When you take the scene offline, the off animation will play.
  • 4.  RE: Playing different scene directors
