alrighty then... I am having some fairly significant issues wherein things look one way in the layout mode, but the sequencer playout is different. It has to do entirely with positioning.. things arre lined up and dialed in nice and tight in the layout, but when I play them out of the sequencer, or export an image sequence, I see gaps, its as if things aren't keeping up if that makes any sense.
The thing about this is, since I can't see the problem in the layout mode, I can't really fix it, and I am at a complete loss.. perf meter never goes above 14-15%. I have a fair amont of visual logic in some of these scenes, is there some sort of lag there? I have for instance 1 element keyframed, and 4 other elements linked to it in VL, so I don't have to juggle 5 tracks worth of animation when it comes to making changes and stuff... could that be the problem? I am well and truly at my wits end....
