I redesigned our Jumbotron scorebar for our upcomng season. The scorebar is fed by the OES scoring system. I have used the colon in the game clock as a tab so that it stays in place and doesn't move left or right based on the horizontal size of the numbers displayed. Here is the problem: at 5 seconds the time display shifts from 00:00 format to 00.0 format. I am a stickler for minimum shift in the timer but the tab disregards the previous tab using the colon and shifts the entire clock left to allow the (.) to align with the tab. The only solution I can think of is to turn off the clock using the colon when the value of the clock is => 5. Am I over thinking this?
