Hello.
I'm wondering if it's possible to *safely* install multiple versions of XPression on one machine.
I usually use designer, but am now delving into using XPression API, which is why I need either studio/dev to quickly test code. I also have had to make packages for other versions of XPression (such as Prime).
The workaround I have rn is team viewering into a separate PC that has studio installed, and running code there remotely. Obviously not ideal, but I'm lazy and don't want to get up every time I want to execute (computer is not near me). Ideally I'd be able to rapidly test everything on one machine.
The alternative is I'd have to reinstall and install XPression versions. I can't keep the studio dongle (it's on loaner), I don't want to deal with setting everything up again.
I've heard horror stories from my coworker about installing multiple versions of XPressions. I'm willing to do registry editing/scripting to make this work.
