  • 1.  Preview Section of Sequencer Interface
    Posted 02-19-2017 09:28
    From the attached picture, we can see the info display box is beside the preview window of the Sequencer Interface.
    Is there a way to move the info display box to the bottom of the preview section?
    Some customers found that the old version XPression interface shows the scene info under the preview. But in new version, the info is moved to right hand side.
    It would be great if the info box can be move by user preference.
    Please advise.
  • 2.  RE: Preview Section of Sequencer Interface
    Posted 02-19-2017 22:14
    You maybe create animation controler for preview with another positions or animation objects and paste on do not used track and disable this track. Write script for tab onPreview - when You see preview, then activete track with preview animation controller. And write script in tab onRender - when played scene track preview in scene Direstor - disable. I not tried, but I think must be working.
  • 3.  RE: Preview Section of Sequencer Interface
    Posted 02-20-2017 01:13
    Hi Tony,
    It is not possible to move it back to the bottom. It was moved because in new versions of XPression you can have multiple items cued in preview at the same time (by using the decimal key to cue them), and then you can swap them all to air simultaneously. In these situations the preview will show a composite image of all cued items and the information area on the right side of the preview will show a vertical list of all currently cued items.
  • 4.  RE: Preview Section of Sequencer Interface
    Posted 02-20-2017 14:35
    Hi Brian, well noted with thank.
