  • 1.  Datalinq Documentation
    Posted 09-25-2018 16:05
    Hi, does anyone happen to have a datalinq document that explains all the various variables/parameter/search/sorting modifications you can make to datalinq data source in xpression. I.E. things like Contests\Contest\Choice
  • 2.  RE: Datalinq Documentation
    Posted 09-26-2018 05:55
    It depends on what your source type is.
    In Excel documents, you can actually do some SQL on them to select based on your datalinq keys.
    For XML documents, you can use XPath to select and search the XML documents ( https://www.w3schools.com/xml/xpath_intro.asp )
