I am trying to cut-down the amount of time dedicated currently to putting replay moves and transitions onto the expression for show use.
Currently:
A client sends an element tape that has the fill and mattes of all the transitions for show use
We encode the tape to disk.
We take the encoded file and drop it into after effects and line up (fill / matte), then export each transition as a (h264 - 29.97 with alpha .mov)
Finally we use the Ross video encoder and encode each to the usable (.avi) format
Desired ability would be:
Encode the tape to disk.
Use the Ross video encoder and encode each to the usable (.avi) format (the full rip)
Here is where I need HELP PLEASE:
I am assuming I would need the full rip on two different layers within the expression (one for the fill and one for the matte)
I know how to trim the in/out points of the clip and can figure out how to align the matte and fill for each transition
***** I am unsure of where to place them in order to make the matte cut the hole so the fill will key ****
IE - One on Background on on layer or both on layers
Lastly:
Can you copy & paste the 'trimmed' in/out point clip and place it onto another layer so I can speedily do what I am trying to do
If there is an easier way to the workflow or if anyone has any helpful tips I would great appreciate your thoughts
