  • 1.  Setting up an XML?
    Posted 11-04-2015 06:15
    Hi, i need to set up a Twitter counter via an XML File located in a lan connected notebook to the Main Xpression machine.
    I made the project, created a text, enabled the Datalink Server, linked it to the XML line that would constantly update but the number wont change, does anyone know what the problem could be? Thanks a lot!
  • 2.  RE: Setting up an XML?
    Posted 11-04-2015 23:16
    Is the XML file being saved when it is updated?
    Is the Datalinq Server reading the XML file from a network share?
    If it is then make sure you are set to polling instead of file change events:
  • 3.  RE: Setting up an XML?
    Posted 11-11-2015 18:25
    Thanks for the reply Garner, if you wish you could send me your e mail address so i can share with you the XML ill be using this Sunday, i cant get it to update the numbers live, maybe you will be able to, thanks!
    Regards!
