  • 1.  MOS Preview Issue
    Posted 11-01-2018 16:33
    So, I've got something that makes no scene. I have a scene that renders correctly in the designer and on air but not when previewed in the ENPS MOS plugin. I two different studios and gateways same issue in both.
    No clue on how to solve this or figure out what is wrong. Thinking it must be something in the OFL Blue box engine but no clue were to start.
    See attached images notice all the missing dot in the ENPS preview. The dots are cylinders turned on there end.
    Aaron
  • 2.  RE: MOS Preview Issue
    Posted 11-01-2018 18:10
    If you share the scene with Ross Video Tech Support, someone should be able to look at it and help you out.
