And yes, I am aware of this:
[QUOTE][COLOR=#000000] Trigger Event Properties
Use the Trigger Event Properties dialog box to edit and configure a Scene Director Trigger from the selected track that will trigger a scene director in other on-air scenes to play.
A scene with a new Scene Director must be sent to an output in order to be triggered.
Properties
Use this section to configure the properties of the Scene Director Trigger.
Trigger in this scene only "” select this check box to look for scene directors in the current scene only.
Scene Name "” use this box to enter the name of the scene with the Scene Director to trigger in other on-air scenes.
Scene Director "” use this box to enter the name of the Scene Director to trigger from the scene.
Action "” select an action for the Scene Director when triggered:
Play "” playout the tracks in the Scene Director.
Pause "” pause the tracks in the Scene Director.
Stop "” stop the tracks in the Scene Director.
Play Range "” select this to set a play range in frames for the playout. Use the boxes to enter or select the play range in frames.
Framebuffer "” use this list to select the framebuffer upon which to search for a scene which matches the scene name provided.
Execute when activated from play direction "” select one of the following options:
Left & Right "” select this option to trigger the Scene Director when the play direction of the track is moving forward or in reverse.
Left "” select this option to trigger the Scene Director when the play direction of the track is moving forward only.
Right "” select this option to trigger the Scene Director when the play direction of the track is moving in reverse only.
OK "” click to apply the changes and close the dialog box.
Cancel "” click to close the dialog box without applying changes.[/COLOR]
I have followed the help description to the letter, but I cannot make the scene react...
