I have matched all the settings in the ADODB Datalinq with what you have described. I had also tried the Excel Datalinq at one point, but the ADODB worked better so I stuck with that. Still the information that is altered in the Excel spreadsheet does NOT update the Xpression project.
I have attached two images. The first shows the Xpression project with the older information. The red circled information no longer matches the Excel spreadsheet with which it is linked. The blue circled information appears as a decimal instead of a percentage.
The second image shows Excel spreadsheet. The red circled information in this is the newer information that fails to update automatically in Xpression. The blue circle shows the percentages that are erroneously appearing in Xpression as decimals.
Also, could you provide an image outlining this? I'm not entirely certain what sort of continuous animation I'm supposed to be applying for a Datalinq connection.
Garner: "And your data will not update in the viewport unless you have Continous animations turned on. (The Blue button at the top of the viewport)"
