  • 1.  Tween Object
    Posted 08-06-2015 04:53
    How do you tween an object such as a bar sliding left and right (tween it's X position from say -150 to 0)?
  • 2.  RE: Tween Object
    Posted 08-06-2015 18:40
    You need to put it on an animation controller, set your keyframes, and that's it. Here's my usual process:
    1) select object
    2) add keyframes (ctrl + k on Windows)
    -do this as many times as needed from the window
    3) open the key graph editor (ctrl + shift + k on Windows)
    4) edit keyframes to where I want them to be/do/act/etc
    Make sure the animation controller is on the Scene Director timeline, and make any timeline adjustments you would like, Bob's your uncle, your object is now moving.
  • 3.  RE: Tween Object
    Posted 08-06-2015 22:47
