  • 1.  XPression embedded Audio AES on AJA Corvid 88
    Posted 12-05-2018 12:21
    we had a Problem with embedded AES output. Video is running great, but when we try to output embedded AES, no sound is coming out of the system. As we now researched, it seems that the corvid 88 can only output 24bit sound, but XPression can't handle this format. Our elder systems with AJA Xena , Kona or Matrox x.mio cards work fine with embedded AES (16bit 48kHz). Is there a solution?
    Thanks in advance,
    Igor
  • 2.  RE: XPression embedded Audio AES on AJA Corvid 88
    Posted 12-05-2018 18:08
    What AJA driver version and XPression version are you using?
    Embedded audio should work exactly the same on the Corvid88 card with XPression as the other cards you have mentioned.
  • 3.  RE: XPression embedded Audio AES on AJA Corvid 88
    Posted 12-07-2018 10:40
    Sorry for the late response. On Monday I will post the necessary details.
  • 4.  RE: XPression embedded Audio AES on AJA Corvid 88
    Posted 12-12-2018 10:28
    We are running the Xpression Version 8.2 build 4446 with AJA driver 12.5.1.330
  • 5.  RE: XPression embedded Audio AES on AJA Corvid 88
    Posted 12-12-2018 10:34
    We also tried XPression Version 6.5 with the same result. No embedded audio. I honestly have no clue about this issue.
  • 6.  RE: XPression embedded Audio AES on AJA Corvid 88
    Posted 02-20-2019 18:09
    Problem solved. The issue was Hardware related and has nothing to do with XPression.
