  • 1.  Play Range Start doesn't change duration of playback in Sequence
    Posted 02-27-2020 14:54
    I have a Scene that has 3 pages and I want to advance past the first page in Sequence mode, so I changed Play Range start to frame 330 and end at frame 930. When that line plays back, it should take 20 seconds, but it's staying online for 31. The content is correct as the system displays page 2 first, but the content for page 3 (should be 10 seconds) stays on for 20. XPression v8.5 build 4611
  • 2.  RE: Play Range Start doesn't change duration of playback in Sequence
    Posted 02-29-2020 09:25
    Hello Jamie,
    If you are playing your items  from the group in "timed" playout mode , try set item timing to be "Scene Director" instead of default "item duration" . It seems to take into account the good duration then.
    Hope it helps,
    Antoine
