  • 1.  Transition in and out
    Posted 06-05-2019 19:34
    I have a question regarding transition or fading in and out. If I have a full screen graphic and I have the transition set to fade in or out, when I take that full screen it transitions to a few frames of black before disappearing. Is there a way to avoid that?
  • 2.  RE: Transition in and out
    Posted 06-12-2019 20:08
    Do you have a pause in the scene director within the same number of frames as you have set on the take item?
    Can you provide a sample project that shows your issue?
