  • 1.  Centre Multiple Objects - When text expands remains in centre
    Posted 05-03-2019 06:47
    Hi - I'm struggling to find an answer to this problem I have been having :
    I would like to centre a group of objects so that if the text is changed the whole group aligns centre to the whole scene.
    You can see in the attachment this is the group of objects I would like to automatically move to the centre when text is edited.
    Thanks to everyone in advance
  • 2.  RE: Centre Multiple Objects - When text expands remains in centre
    Posted 05-03-2019 17:13
    Hey Paul,
    This might be the opposite of what you are trying to do, but will move objects along position X based on half the bounding box size.
    You would probably want to add another tab with two selector blocks and some equal to or greater functions to stop the X position from exceeding the safe title location.
    https://rossvideoltd.sharepoint.com/:u:/s/services/TechnicalSupport/EWRYKbAZGUROpBcXLjMRF9QBaODNz6GaKhgY_ehSW_wYMg
  • 3.  RE: Centre Multiple Objects - When text expands remains in centre
    Posted 05-05-2019 21:38
    I understand what you're trying to do. I've also done this myself, but thanks for bringing it up again! Made me realise a few mistakes I had done the first time around.
    What you want to do, is take all the three elements, the CITY, DIVIDER and ARENA and put them in a group. This makes the 0-point on the X-axis the center of the graphic.
    Now that we have the center point you use the X-position of the CITY, to set the X-position of the DIVIDER. Then you use the X-position of the DIVIDER to set the X-position of the ARENA.
    As you might see from the Visual Logic, I take the X-position of the CITY, add the BoundingBox.WidthScaled, and a small value (20) to set the X-position of the DIVIDER. Reason I use the WidthScaled is because if you end up using the Auto-Squeeze on either text, this value will be the correct one, while it might be too long if you squeeze the text.
    Now, that you have all texts positioned correctly one after the other, and they are all based on the X-position of CITY. You take the total width of all the elements (dont forget to add the space divider twice), and divide by -2, and you get the negative value on the X-axis to set CITY. Voila... Done!
    See picture:
    (The three blocks at the top is only there to force the pivot point to be on the left side of the divider graphic, even if you put in a wider graphic there).
  • 4.  RE: Centre Multiple Objects - When text expands remains in centre
    Posted 05-06-2019 01:45
    Thanks Aleksander & Peter for your help.
    Works perfectly. Thank you!
