  • 1.  Fonts wont load in Xpression.
    Posted 02-08-2019 01:32
    I have 3 machines im running , and one of the 3 will not load fonts into in xpression. (they are loading on the machine and loading on other programs)
    Has anyone ever ran into this issue?
  • 2.  RE: Fonts wont load in Xpression.
    Posted 02-08-2019 02:45
    Make sure the font you are using is located in the fonts folder that your XPression project creates when you set up its project structure. If it is in that folder, try restarting the software.
