  • 1.  database of images to cube?
    Posted 01-29-2012 22:51
    Is there a way to use a database (access) to populate the sides of a cube with images? I can get the database working for text fields but not materials...
    chris
  • 2.  RE: database of images to cube?
    Posted 01-29-2012 23:27
    Go under material>edit...
    Here are the datalinq for material...
    In your case, create a material for each face of your cube, apply them, and link each one with datalinq...
  • 3.  RE: database of images to cube?
    Posted 01-30-2012 21:13
    thanks Vincent..
  • 4.  RE: database of images to cube?
    Posted 01-30-2012 21:29
    I'm trying to add a new Datalinq Server.. I select ADD NEW, then #1 ADODB Datalinq Source.. select template.. pull down menu to Access (ODBC).. I hit OK.. then what?? I replaced the info within the brackets but keep getting Data Source name not found and no default driver specified.. so i'm entering the info. incorrectly. Do you have a photo of what your ADODB Datalinq Config. window looks like?
  • 5.  RE: database of images to cube?
    Posted 01-31-2012 01:30
    This is mine right now:
    Provider=Microsoft.Jet.OLEDB.4.0;
    Data Source=c:TEST.mdb;
  • 6.  RE: database of images to cube?
    Posted 01-31-2012 03:17
    Thanks Brian.. that bit of info. was all I needed..
