  • 1.  Problems with Codec for Banner animation
    Posted 03-12-2020 18:50
    Hello all!
    My studio is now using Xpression and I am still learning alot.
    Please be bare with me for i am new to all of this.
    Our client has sent banners from after effects.
    The graphics artist is exporting them and making them into PNGS.
    Now, i was give some banners that are suppose to animate.
    I used the CODEC to convert them from mov. to avi
    After building it I check the preview but it doesnt play.
    Same with play out.
    The PNGS work fine for it just cuts in then cuts out.
    however if they want the banners to transition , it does not work.
    What am I doing wrong?
  • 2.  RE: Problems with Codec for Banner animation
    Posted 03-12-2020 18:55
    It doesn't play in After Effects, Media Player - as a AVI file or is not playing in XPression?
  • 3.  RE: Problems with Codec for Banner animation
    Posted 03-12-2020 18:57
    It doesn't play out in Xpression.
    works fine in After Effects and Media Player.
  • 4.  RE: Problems with Codec for Banner animation
    Posted 03-12-2020 18:59
    Did you use the AVI file as material to map background or quad?
  • 5.  RE: Problems with Codec for Banner animation
    Posted 03-12-2020 19:00
    I used the QUAD.
    Can you instruct me what to do exactly so I can do this right ? :)
  • 6.  RE: Problems with Codec for Banner animation
    Posted 03-12-2020 19:13
    For the first step follow the instructions from this tutorial: https://youtu.be/f8ZpRn9k8E4 to auto play the clip or for advance control of the clip playback see this one: https://youtu.be/ENNMhxolMWk
    Have FUN!
    Gabriel
