  • 1.  Xpression Dashboard keyboard shortcut
    Posted 12-21-2018 13:03
    when i control a channel on xpression at graphite true dashboard , it would be good if the function "CUE", "EJECT" and "Take Online" can be set to some keyboard shortcut like C= Cue, E= Eject and Enten = Take online is that possible ???
  • 2.  RE: Xpression Dashboard keyboard shortcut
    Posted 01-10-2019 01:40
    You can set custom hotkeys to pretty much everything via XPression.
    You can go to edit -> keyboard mapping.
    If you want to be even more complex, you can also assign scripts to hotkeys as well.
  • 3.  RE: Xpression Dashboard keyboard shortcut
    Posted 01-10-2019 17:40
    Make sure you make a new keyboard layout. You can't directly edit the default layout.
