  • 1.  Using the drop shadow effect
    Posted 09-25-2015 01:37
    I have made a scene for Pics and I put a looping BG on the scene and also a Drop Shadow onto the "Pic" quad....I set the scene to dissolve in at 10 frames. But whenever I dissolve between 2 of the pics the dissolve is very choppy and not smooth. I have published the material on the Pic so that I can import 50 Pics for a pilot that we are shooting. Is the drop shadow and the looping background too much for one scene?
  • 2.  RE: Using the drop shadow effect
    Posted 09-25-2015 02:25
    I took off the background and the dissolves still look choppy?? Why does the Drop Shadow effect make the transitions choppy?
  • 3.  RE: Using the drop shadow effect
    Posted 09-25-2015 06:51
    Mr. Henderson.. I assume in the sequence side you have the default effect 10 frame dissolve for both on and off. Make the effect a cut for the off and it gives you your required dissolve effect but it doesn't stutter. That's been my work around for this exact scenario.
  • 4.  RE: Using the drop shadow effect
    Posted 09-25-2015 18:30
    Chris, if the above suggestion doesn't work please provide a copy/sample of the scene that has the issue.
