So I have an additional question for this Visual Logic. What I would now like to do is add another condition. Is it possible to maintain even spacing between rows even if one or more of the bullet points have 2 or 3 lines of text?
I had an earlier post about using 1 full screen template for various numbers of text lines (2-6). Willie was a big help with the visual logic to make this possible
Now I want to take this a step further and enable the text lines to adjust on the Y axis according to the height of the lines while at the same time filling out the body as it is set up with this visual logic example.
My questions are:
1) Is this possible at all?
2) Is this possible through visual logic or would the answer be through script?
I posted this question on my previous post but wasn't sure it just got buried at the end of my original question. Any help would be greatly appreciated.
