Hi guys,
I've asked this question also to techsupport but maybe somebody here on the forum also knows the answer.
I'm using a Studio SCE (Single Channel Edition).
For a project in a few days I need to use a live input and use that in my scene.
Now as far as I've been told, you need to define a second capturecard as an input inside XPression in order for this to work.
The problem is now that I'm having a conflict with one of my capture cards in my pc which is an older version of the card which I'm using as an output. I've already spent 8 hours trying to get this card to work and meanwhile cursing the damn thing.
Right now I've come to the stage that I'm considering of buying a new card of the same type of the one which is already in the system. But before I go and spend a lot of money I would like to know for sure that this is supported in the SCE-version of XPression.
So when you use the XPression SCE-version you are limited to only 1 outputcard but can you also add an second card as an input?
@bolson,
@bford ?
Best regards,
Kenneth
