  • 1.  Slab-issues
    Posted 11-13-2015 08:49
    I'm trying to use the new Slab-primitive but I'm having an issue when trying to apply an effect on it.
    The dropshadow casts a shadow on the face of the slab too.
    Anybody else has seen this behaviour?
    Cheers,
    Kenneth
  • 2.  RE: Slab-issues
    Posted 11-19-2015 13:17
    Hi Kenneth,
    What version of XPression are you using?
    Can you post a sample project that demonstrates this issue?
  • 3.  RE: Slab-issues
    Posted 11-23-2015 11:38
    Hi Garner,
    I am using 6.2 build 3468.
    You can see an example here: https://www.dropbox.com/s/mmhtod91pwd1my5/Valkuil.xpp?dl=0
    When you rotate the slab on the Y-axis you will see the shadow drop on the face.
    Best regards,
    Kenneth
