  • 1.  Datalinq not reading #00 from Excel Sheet
    Posted 12-21-2018 22:31
    I am using Datalinq to pull in information from Excel. I have a player with a jersey #00; however, when I convert the Excel cell to a text format , Datalinq does not recognize any information in that certain cell. When I try to format the cell to display 00, Datalinq only reads the cell as #0. Has anyone else ran into this same problem, and how did you go around solving this issue?
    I am not very knowledgable on scripting, but could there be a way to script out when the text value from Datalinq shows #0, it can display #00? Thanks.
  • 2.  RE: Datalinq not reading #00 from Excel Sheet
    Posted 12-22-2018 02:21
    You're converting the excel file to a text format? Is there a reason to do that; have you tried importing it as a ADODB database?
  • 3.  RE: Datalinq not reading #00 from Excel Sheet
    Posted 12-22-2018 12:55
    Try this:
    If you are using XLS files (not XLSX) and using the JET OLE db connection string, in RegEdit, navigate to this registry key
    [HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\ Jet\4.0\Engines\Excel]
    and set the TypeGuessRows field to 0.
    If this doesn't solve the issue, you'll need to share the XLS file with us to investigate.
  • 4.  RE: Datalinq not reading #00 from Excel Sheet
    Posted 12-24-2018 20:59
    Is there a similar key for XLSX files? I seem to recall having this issue myself and I set a bunch of those registry keys to no effect. Ended up just hard coding the jersey number on the take item itself.
  • 5.  RE: Datalinq not reading #00 from Excel Sheet
  • 6.  RE: Datalinq not reading #00 from Excel Sheet
    Posted 12-27-2018 16:36
    I am interested in learning if this worked. I am having the same problem with an Excel database.
    Update: I am only having the problem on the actual Xpression machine. Just started trying to troubleshoot on an offline system and am not seeing the same result. My "00" are displaying properly on my offline machine.
