  • 1.  Using Visual basic from another computer
    Posted 01-17-2019 20:18
    Hi there!
    We are using a visual basic application we made to manage some xpression layers , rather than from the xpression GUI. now we need two operators at the same time. it is possible to install that application in another computer and connect remotely to the xpression engine?
    thanks
    Diego
  • 2.  RE: Using Visual basic from another computer
    Posted 01-22-2019 21:02
    Hey, the API is local only so you have a couple of options. Either make some kind of service that runs locally on the XPression that sends the API commands to XPression or you can control XPression from Dashboard. We now have an option called DashAPI that connects via network to XPression and allows a lot of API control as well as having a default dashboard for remote control of Sequence.
  • 3.  RE: Using Visual basic from another computer
    Posted 01-24-2019 16:45
    This sounds interesting - where can I get or find out more about the default dashboard for remote control of Sequencer? And the DashAPI info?
  • 4.  RE: Using Visual basic from another computer
    Posted 01-24-2019 16:48
  • 5.  RE: Using Visual basic from another computer
    Posted 01-24-2019 21:29
    Thanks - this is great. Where do I get the Dashboard XPression panel used in that video?
