Lyrics "import text to template" with 2 lines but with different font name, size and color.
  • 1.  Lyrics "import text to template" with 2 lines but with different font name, size and color.
    Posted 12-26-2019 00:53
    I make a 2 line lyrics template in a scene assign different font name, size, and color with each line and then when I "import text to template" to populate the lyrics in the sequencer. yes, it produced all the lyrics in the sequencer the 2 line lyrics per scene but it uses the default or the other font in all lines in a scene. and I have to assign it again manually to every scene in the sequencer and it was tedious work to do after all.
    how can I do this as it looks like a template that I made?
    for example:       1 line (Text) font Arial, size 20, color white
                               2 line (Text) font Michland, size 6, color red
  • 2.  RE: Lyrics "import text to template" with 2 lines but with different font name, size and color.
    Posted 03-04-2020 01:27
    Hey Jim,
    I would do that using Visual Logic.
    From your question I cannot distinguish if you are using one textobject with 2 lines in it, or if you are using 2 textobjects.
    But basically, you would import those lyrics into a "dummy" or "hidden" textobject in your scene.
    Next you would take the contents and append them to your visible text-object using font tags.
    Look at the image below to see the Visual Logic.
    If you are importing the two lines into one single textobject, you will need to add a bit more Visual Logic to be able to split the two lines.
