I'm not familiar with using dashboard or using dashboard to manage data, but if you see values are being changed on the dashboard side but when you open the actual Data.XML file those attributes aren't reflecting the new data, it suggests to me that changes aren't being committed.
If you ARE seeing the data within your XML file being committed then some things that come to mind are:
- Datalinq Manager hasn't been added on the Xpression project side (this sometimes happens when setting a project up and opening it elsewhere)
- Text objects aren't set to live update
- The datalinq server sources are named incorrectly and are mismatched to what the XPR is looking for.
