  • 1.  Can template data in take items be synchronized?
    Posted 02-10-2019 14:58
    Hi!
    One of my scenes contains many published objects. I put this scene in Sequencer into several different groups. They are independent take items for XPression, of course. I want them to be synchronized - when I complete all the template data in one take item, the others should have the same values.
    In other words, they should behave as if they were cloned. Is there any easy way to do this?
    I know that I can insert all values in one take item and copy it to different groups, but that's not what I mean because the sequence has a very extensive structure and you would have to remember where to insert them.
    I suppose the only way to do this is to use a script. If so, where to insert it? Is it possible in the Sequencer? Can anyone help me with this?
  • 2.  RE: Can template data in take items be synchronized?
    Posted 02-10-2019 17:19
    Does your operator go into the first scene and manually enter the data? Is it possible to setup a dashboard where the data is entered and delivered to as many scenes as you like?
  • 3.  RE: Can template data in take items be synchronized?
    Posted 02-10-2019 18:03
    Yes, the operator must enter the data manually into the first take item. The next instances of the same scene should fill in automatically. I'd rather not use Dashboard.
