  • 1.  Code for 'center text in a text box vertically' needed
    Posted 02-01-2012 22:57
    Anybody have a bit of code that centers all the text in a text box.. i already have code on there to word wrap..
    thx
  • 2.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-03-2012 03:59
    Chris,
    Let me ask this for clarification. What do you want? Do you want to always center the text that is typed in it's bounding area?
    -g
  • 3.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-03-2012 04:03
    I've got 4 lines of text within a text box (no more than 140 characters).. coming from a database.. if i have only one line of text, have it centered.. if it's two lines of text, centered with word wrap.. i don't want the text squeezed.. 3 & 4 lines of text, centered and word wrapped..
  • 4.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-03-2012 09:14
    @Chris:
    How does your script to word-wrap look like?
  • 5.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-03-2012 21:36
    Dim maxWidth As Double
    Dim newText As String
    Dim line As String
    Dim strWord As String
    Dim list As Array
    maxWidth = 400 'maxWidth = Self.AutoSqueezeWidth
    If Self.GetTextWidthS(Text) > maxWidth Then
    list = Split(Text, " ", -1, 1)
    newText = ""
    line = ""
    For Each strWord In list
    If (Self.GetTextWidthS(line & strWord) > maxWidth) Then
    newText = newText & line & vbCrLf
    line = strWord & " "
    Else
    line = line & strWord & " "
    End If
    Next
    Text = newText
    End If
  • 6.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-05-2012 17:17
    unfortunately all the scripts i've been given don't work properly for this task. They work in design mode but not when taking data from a database.. if I have a 4 line data coming in i can adjust the Y so it's centered correctly for every 4 line.. but then when a 1 line (or 2 or 3)comes in it's not centered.. if I adjust it for a 1 line to be centered, then the 4 line is way off.. if I had an option to adjust the LEADING of a row in the sequencer that could be a workaround.. i'll have the 1 line centered and manually adjust leading on 2, 3 & 4..
    Perhaps if I had a expert teamview in to see what it looks like as I take the data in a proper fix will be found.
    regards
    ps.. thanks ross guys, I've been given a variety of scripts by them, they've been helpful..
  • 7.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-07-2012 00:57
  • 8.  RE: Code for 'center text in a text box vertically' needed
    Posted 02-07-2012 08:02
    @Chris:
    My idea for a solution. It is not tested but I think it is worth to give it a try.
    put your text box into an animationcontroller with 4 positions which presents the 4 possible Y-positions for 1 to 4 rows of text. with your script you are able to count the amount of rows. Take the amount of rows as a reference for the position of the animcontroller and jump to that postiion.
    Hope this helps. Give me a note.
    regards
    Tom
