Hello
we have a Tessera setup with one Tessera Master and two Tessera Blueboxes (4 SDI out each). Version 9.5.
We noticed, if publishing more then 3 Objects for modification in the sequencer, the objects won't appear correct on the Tessera Bluebox outputs.
E.g. I have one published TextObject on a scene, using a special Font -> Font shows correct on the output.
If I have multiple Textobjects published -> Font shows as Arial on the output.
Similar with QuadObjects.
If we want to publish 10 team-logos, to modify size/scale, the Logos won't show on the output.
Only publishing one or two QuadObjects works fine.
Anyone else run into this?
Best Regards,
Remo
