Hello all,
I'm experiencing some strange behaviour in a project I'm building.
I have a scene which has a lot of different slabs which I'm animating each independently.
On every slab I also had to put 3 spotlights which I carefully added on each slab individually to make sure that the light is not casting on another slab.
Now when I play my animation, after slab 15 animates in, I get a much brighter light which is cast on all of the slabs and which eventually fades out, but the flash is not something I can use.
Is there a limitation on the number of spotlights you can use?
Below you can find a package that includes the scene I'm referring to.
I'm using build 3468.
Thanks,
Kenneth
