  • 1.  Project pegging the performance bar when using inception
    Posted 03-18-2019 11:13
    I am building a new project (it uses a lot of animation) for the debut of an upcoming show. When I load the project on Xpression by itself and connect to the data server, it works fine. However, when I load the rundown through Inception and play the scenes out, the performance increases to over 200%. Has anyone ever experienced this?
  • 2.  RE: Project pegging the performance bar when using inception
    Posted 03-18-2019 17:02
    I found it was 1 full screen causing the issue. I am currently trouble shooting it and will give an update when I know something more.
  • 3.  RE: Project pegging the performance bar when using inception
    Posted 03-19-2019 13:00
    I figured out that it was 1 specific element in the full screen. I added a drop shadow to a bullet (a png image) and I believe this was the cause.
