  • 1.  Layout Editor Lag - Solved
    Posted 10-14-2019 13:38
    New user here. I am experiencing significant lag when I update my datalinq key value in the layout editor.
    I think I'm using a modest amount of visual logic over a few tabs, and only small number of objects.
    What are common sources of lag in the editor/visual logic, where should I be looking? Are there any common mistakes that might be causing this? Any help would be appreciated. Thanks!
    Edit: I solved the problem, but I'm going to leave a note if anyone else experiences this.
    Turns out our Xpression machine was disconnected from its outputs and reconnecting it solved the lag issues.
  • 2.  RE: Layout Editor Lag - Solved
    Posted 10-14-2019 18:40
    I'm having a lag problem too. Do you mean the actual physical cables from the rack unit were not connected?
    That's not my issue. NGSS query time seems longer than it should be.
  • 3.  RE: Layout Editor Lag - Solved
    Posted 10-14-2019 19:04
    To answer your question, yes.
    I discovered another (perhaps larger) contributing factor later today though. I found that moving the excel file that populates my datalinq server to a local drive really sped things up.
