  • 1.  How do you create the reflection?
    Posted 01-29-2012 16:35
    I have created a cube with still photos on the front, back and two sides....how do I give it the reflection?? Thank you for any help y'all may be!!
  • 2.  RE: How do you create the reflection?
    Posted 01-31-2012 16:44
    not sure chris but i think you need a reflection jpg as a child to the cube?? anyone?
  • 3.  RE: How do you create the reflection?
    Posted 05-05-2012 21:31
    Xpr Reflection image
    I made a 2D photo with a reflection. It is possible with Xpression. It is possible to animate the pictures with te reflection.use Renderview to make a copy and flip it -180 degrees and put a mask on it.
  • 4.  RE: How do you create the reflection?
    Posted 05-06-2012 20:13
    Duplicate your object.
    Move it along its y coord so it appears underneath.
    DO NOT FLIP/ROTATE
    Go to texture coord.
    Set Mode = Mirror
    Y=1
    Child that to your original object.
  • 5.  RE: How do you create the reflection?
    Posted 05-06-2012 21:18
    Gregory,
    that's a nice tip now i can built the reflection a bit faster.
    you are right don't flip it but mirror it so the coordinates can stay on zero
    thanks
  • 6.  RE: How do you create the reflection?
    Posted 05-07-2012 20:23
    Can you do this for groups?? Or does it have to be individual objects?
    Chris
  • 7.  RE: How do you create the reflection?
    Posted 05-07-2012 20:27
    Chris,
    You can use a group with this method, but you will need to adjust each objects Texture Coord individually.
  • 8.  RE: How do you create the reflection?
    Posted 05-07-2012 20:45
    Thank you
