  • 1.  Xpression Stream Deck plugin
    Posted 01-13-2020 17:29
    I am looking for the streamdeck plugin for xpression. The XPression U: Setting Up an Elgato Stream Deck for use with XPression (Basics 172) mentions the plugin but doesn't say where it can be downloaded. I was hoping some one can direct me to where i can get it.
  • 2.  RE: Xpression Stream Deck plugin
    Posted 01-13-2020 17:36
    Hey Derek,
    I'll send you the installer.
  • 3.  RE: Xpression Stream Deck plugin
    Posted 01-20-2020 08:54
    Hello Im also searching for the Plugin. Can u send it to me ?
    Best Regards
  • 4.  RE: Xpression Stream Deck plugin
    Posted 01-20-2020 15:58
    Hi, And for me too, pls
    Br Ingemar
  • 5.  RE: Xpression Stream Deck plugin
    Posted 01-27-2020 19:25
    Hey Brandon Derry - Would you be open to sharing a copy of your installer file with me as well? I'm playing around with the Stream Deck using the OS X version of the Stream Deck software, and the OS X version of Dashboard. Ultimately I'll end up moving things to a PC setup, but starting out on MAC since it's what is readily available. Is the plugin platform dependant?
  • 6.  RE: Xpression Stream Deck plugin
    Posted 01-27-2020 19:34
    Hey all,
    For future reference, please reach out to techsupport@rossvideo.com to receive software downloads that aren't available on the website!
