  • 1.  Fantasy Leader Board
    Posted 10-28-2019 06:49
    Hi Ross Community, a client asked me to build a fantasy leader page that is linked to NFL stats on GSIS. My question is, how do I build the leader page where it updates in real time. Meaning, if player C moves up from 3rd place to 1st place, how does it update automatically to move that player from third place to first place? Any thoughts? I appreciate your support!
  • 2.  RE: Fantasy Leader Board
    Posted 10-28-2019 18:42
    Following this one! I know the sort Block and such can be used to make some of this happen...
    But I would love to see a tutorial (XPression U) of how to do an animation of sorts moving these entries when someone moves up/down on the table.
  • 3.  RE: Fantasy Leader Board
    Posted 10-29-2019 18:25
    if iam not wrong you can make each leadership group content name score and rest data what you want. and use short block to move that group at top when the point is highest and same on ...
  • 4.  RE: Fantasy Leader Board
    Posted 10-30-2019 15:51
    I would recommend you just turn live updates off on the datalinqs and just have the scene update on a scene by scene basis. You're likely going to be switching between different categories a lot so it's just cleaner and easier to have it update each time you take the scene to air rather than having things update live. We do this for our GSIS Leaderboards and it works great.
  • 5.  RE: Fantasy Leader Board
    Posted 10-30-2019 19:36
    Sunil + Drew, I’m interested to try both your recommendations. Thank you!
    Is there a video on how to use short blocks, first time I’m hearing about it. I will be sure to check Ross U as well, thank you all!!! Really appreciate your inputs 🙏🏽
  • 6.  RE: Fantasy Leader Board
    Posted 11-03-2019 15:38
    i have just share a post with project file, but there is another issue and i also need help but i think you will get your answer over that project and there your problem is solved. the post name is Comparing integer. and i drive those values with dashobard and datalinq.
    https://support.rossvideo.com/hc/en-us/community/posts/360054784711-Comparing-integer-
    here ...
    thank you
