Hi Brian,
I'm using Studio SCE 4.1 build 2141 and Studio SCE 9.0 build 4842 (32-bit), both version got the same issue.
Here is the code snippet:
private void snapshotTimer_Elapsed(object sender, System.Timers.ElapsedEventArgs e)
takeSnapShot();
private void takeSnapShot()
Console.WriteLine("Take a Snapshot");
string snapshotPath = Path.Combine(xpProjectPath, "Snapshots");
string tgaExt = ".tga";
int s = 0;
int w = 1920;
int h = 1080;
if (!Directory.Exists(snapshotPath))
Directory.CreateDirectory(snapshotPath);
snapshotPath = Path.Combine(snapshotPath, DateTime.Now.ToString("yyyyMMdd_HHmmss"));
xpScenes[curOnlineScene].GetRenderedFrame(s, w, h, out xpSnapshot);
Console.WriteLine("Save File to: {0} - {1} - Size:{2}", snapshotPath + tgaExt, xpTool.ImageToFile(xpSnapshot, xpToolsLib.IMAGE_TYPE.IT_TGA, snapshotPath + tgaExt), xpSnapshot.Size);
Here is the XPression log:
04-11-19 11:46:41.194: Loading project: D:\XPression Bug Test\LiveIn_Time\LiveIn_Time_v1.xpf
04-11-19 11:46:41.196: Project LiveIn_Time_v1.xpf was saved using version . build .
04-11-19 11:46:41.228: Projects loaded: 1, memory in use: 8.764 MB, delta: 180.8 KB, largest block available: 1.854 GB, efficiency: 19%
04-11-19 11:46:41.231: Active project is now: LiveIn_Time_v1 (D:\XPression Bug Test\LiveIn_Time\LiveIn_Time_v1.xpf)
04-11-19 11:46:41.259: Active scene is: LiveIn (1)
04-11-19 11:47:00.250: Scene Online >>> "LiveIn" (1) on Framebuffer 1 Layer 0 Trans Cut
04-11-19 11:47:14.211: Largest available memory block size: 1.847 GB Total Memory Allocated: 8.907 MB Process Memory Used: 971.7 MB
04-11-19 11:48:14.213: Largest available memory block size: 1.847 GB Total Memory Allocated: 8.916 MB Process Memory Used: 1.181 GB
04-11-19 11:49:15.212: Largest available memory block size: 1.684 GB Total Memory Allocated: 8.929 MB Process Memory Used: 1.414 GB
04-11-19 11:50:16.213: Largest available memory block size: 1.451 GB Total Memory Allocated: 8.941 MB Process Memory Used: 1.646 GB
04-11-19 11:51:17.214: Largest available memory block size: 1.211 GB Total Memory Allocated: 8.955 MB Process Memory Used: 1.889 GB
04-11-19 11:52:17.216: Largest available memory block size: 1002 MB Total Memory Allocated: 8.973 MB Process Memory Used: 2.129 GB
04-11-19 11:53:18.217: Largest available memory block size: 763.8 MB Total Memory Allocated: 8.985 MB Process Memory Used: 2.353 GB
04-11-19 11:54:19.218: Largest available memory block size: 525.7 MB Total Memory Allocated: 8.998 MB Process Memory Used: 2.585 GB
04-11-19 11:55:20.219: Largest available memory block size: 279.6 MB Total Memory Allocated: 9.011 MB Process Memory Used: 2.833 GB
04-11-19 11:55:42.219: Largest available memory block size: 192.3 MB Total Memory Allocated: 9.017 MB Process Memory Used: 2.918 GB
04-11-19 11:56:03.219: Largest available memory block size: 112.9 MB Total Memory Allocated: 9.021 MB Process Memory Used: 2.996 GB
04-11-19 11:56:19.220: Largest available memory block size: 49.45 MB Total Memory Allocated: 9.025 MB Process Memory Used: 3.058 GB
04-11-19 11:56:25.220: Largest available memory block size: 25.64 MB Total Memory Allocated: 9.026 MB Process Memory Used: 3.081 GB
04-11-19 11:56:30.221: Largest available memory block size: 7.711 MB Total Memory Allocated: 16.94 MB Process Memory Used: 3.112 GB
04-11-19 11:56:36.218: Largest available memory block size: 9.762 MB Total Memory Allocated: 9.028 MB Process Memory Used: 3.097 GB
04-11-19 11:56:38.266: Scene Offline <<< "LiveIn" (1) on Framebuffer 1 Layer 0 Trans Cut
04-11-19 11:56:38.304: Releasing 1 out of 1 allocated COM scenes.
Here is the Debug Monitor log:
04-11-2019 11:46:41 Notify: Loading project: D:\XPression Bug Test\LiveIn_Time\LiveIn_Time_v1.xpf
04-11-2019 11:56:29 Error: Engine error on call GetRenderedFrame (failed rendering frame).
04-11-2019 11:56:31 Error: Engine error on call GetRenderedFrame (failed rendering frame).
04-11-2019 11:56:33 Error: Engine error on call GetRenderedFrame (failed rendering frame).
04-11-2019 11:56:35 Error: Engine error on call GetRenderedFrame (failed rendering frame).
04-11-2019 11:56:37 Error: Engine error on call GetRenderedFrame (failed rendering frame).
