  • 1.  Virtual Set AR System
    Posted 05-29-2017 03:40
    Hi
    We recently have an object called MV_virtualSet_2 to control the virtual set background. Please see the attached photos as reference. We have already enabled the alpha channel and we want the object opened as default as the background layer but not as an AR object. But now it has been set as an AR object by default. We don't want to toggle it via "man" icon every time in the UX interface as it is quite troublesome. Do you have any idea how we can make a change in Xpression project so that we can make it as default in the background layer and we don't need to change it every time when we open the virtual set?
    Thanks.
  • 2.  RE: Virtual Set AR System
    Posted 05-29-2017 17:32
    Open the porject in XPression without UX Driver and select the object MV_virtual Set_2 in the Object Manager. Then go Object Inspector > Rendering > And Un-check "Alpha". Then SAVE the XPression project. Re-launch UX Driver and UX Experience.
