  • 1.  Transition Logic not working in Inception
    Posted 07-09-2019 13:50
    I set up Transition logic rules for 3 lower thirds.
    >L3 "Side Data" and L3 "Banner with Data" are 2 different scenes that are on different layers so they can be on the screen at the same time.
    >L3 "Banner No Data" is a different scene that when played should animate the above 2 scenes out.
    I'm pretty sure I have the Transition Logic set up correctly because when I play it out from the Sequencer, it works.  However, once I publish the project and try to play it out in a show rundown through Inception, it does not work correctly.
    Is this a common problem or is there something I am doing wrong?  I can give more details on the Transition Logic rules and Scene Directors if needed.  Thank you for any help in advance.
  • 2.  RE: Transition Logic not working in Inception
    Posted 07-10-2019 13:25
    I think I solved the issue, at least for my purposes.  I put each lower third on a different layer and it seems to be working fine now.
