  • 1.  Switching project from 1080 to 720
    Posted 03-16-2012 02:00
    I started a project in 1920x1080, now i need to convert the project to 1280 by 720.. i made the change within hardware settings but i can't find any other places to change.. what other changes do I need to make? my canvas tick marks are still 1920x1080 and when I export a movie or still sequence they are still 1920x1080.. i tried starting a brand new project with the proper settings but various elements don't seem to get imported back so that route doesn't work..
  • 2.  RE: Switching project from 1080 to 720
    Posted 03-16-2012 14:40
    Chris,
    Have you tried using the 'Covert Project Mode' under the 'Project' menu? Or did you just try to create a new project and set the proper output format?
    -g
  • 3.  RE: Switching project from 1080 to 720
    Posted 03-17-2012 06:55
    thanks glen.. i saw that but didn't do it.. i just tried to create a new project and set the proper output format but I had some corrupt elements and starting from scratch didn't work..
    c
