Hey everyone.
I have a scene for which we have created a simple dashboard panel. The scene tests perfectly in our studio but when we send it over to our client, things just aren't working correctly. The dashboard / datalinq do connect, as the take online / advance functions work, but the bit which is set to put text in a specific location based on dashboard input is putting the text in the wrong place.
My only thought at this point is that the issue revolves around version disparity. I built the scene with 7.1, and they are using 8.5. Its not typically an issue to go that direction... from older to newer, but at this point its sort of the only wildcard.
Has something changed with Datalinq in 8.5 that could cause it to have issues with files created by older versions?
