Hi all,
I was having issues with some graphics which were being shown with occasional lines and artefacts on screen.
I have checked the original TGA-sequence which I rendered with the VideoCoder and that was clean. I didn't think that would have been the issue because it's not always and never on the same point. So it's either in XPression or in the videocard. I'm using the AJA Kona 3G. I already replaced the cards by those from another XPression to rule out any issues with this particular card but the issue still remains. As a next step I have updated the drivers on the AJA-cards. Now I can't even assign the cards anymore to XPression. It doesn't see the cards anymore.
When I check in the system, the cards show that they are properly installed and there are no errors. So it seems to me that XPression is not yet capable of using the AJA-cards with the latest drivers. Could that be possible?
The Aja-driver which I'm using is 10.6.1
Also, if anyone would know where these lines or artefacts are coming from, please do share.
Thanks,
Kenneth
