  • 1.  Visual Logic not updating Datalinq Funcion Block
    Posted 01-29-2018 18:31
    Anyone else using Datalinq Function block with .csv file in Visual Logic? I am using XPression V7.0 build 3798 and Visual Logic does not seem to receive Datalinq updates. Dataling is updating Data Sources in Materials & Text outside of Visual Logic. And Visual logic is updating other values in real-time, just not updating the Datalinq function blocks. Wondering what I am doing wrong or if it is broken? Thanks in advance for any help or suggestions.
  • 2.  RE: Visual Logic not updating Datalinq Funcion Block
    Posted 01-30-2018 00:30
    I'm doing something similar ... using Visual Logic and a Dashboard (XML file) datalinq to change a material color and also change a text object straight from the same Dashboard panel datalinq. The straight datalinq to the scene text object works as expected. The data doesn't "seem" to update if I look at in VL editor BUT if I take the scene to air and make changes then I can see that they are happening. You could try sending it to the sequence and taking it online as it may be working, you just can't see it in the VL editor (or the layout view).
  • 3.  RE: Visual Logic not updating Datalinq Funcion Block
    Posted 01-31-2018 05:13
    Thank you for your reply. I ended up linking to the Text in the scene and using the text as a source in Visual Logic. Thanks again.
