  • 1.  XPression Animation Ease In/Out
    Posted 07-09-2013 22:07
    This is a basic animation question. I can not figure out how to ease in/out with the animation key graph editor. I have tried modifying the various Interpolation Spline options on the keyframe with not change. I am used to seeing BSpline handles to modify the tangents or other attributes. Any guidance would be appreciated... am I missing where to find this in the manual?
  • 2.  RE: XPression Animation Ease In/Out
    Posted 07-09-2013 22:49
    Hi Paul,
    In the KeyGraph editor, first select which property you would like to modify. Then select both keypoints by dragging a rectangle over those two keypoints. They will light up in yellow. Next in the Interpolation you can select the type of spline you would like te use. But if you take the bezier, you will get the ease in/out by default.
    If you use the TCB spline, you can adapt the animation by changing the Bias and Continuity etc. on each keyframe.
    Hope this helps a little bit?
    Kenneth
  • 3.  RE: XPression Animation Ease In/Out
    Posted 07-10-2013 02:44
    Kenneth, Thank you. The key was to select two keys. :) It's all working as expected now. Thank you for your help.
