I have a show coming up where I have a spreadsheet full of names. I want to setup Sequence to pull data from that spreadheet using a Rel ID based on the Performance # column. So Perf would be column A and Names is Column B. Then all the data is in Rows. So If its TakeID 1 I want the Team name in the Performance 1 row I just am having some trouble with this actually working. Anyone have thoughts?
